Up Topic Welding Industry / General Welding Discussion / Rubber gasket hole punch set
- - By theelee87 (*) Date 08-15-2012 03:23
Does anyone know of a place online to buy a good quality rubber gasket hole punch set? Any help or info would be appreciated thanks!
Parent - By 99205 (***) Date 08-15-2012 03:42
Have you tried Google?
Parent - By G.S.Crisi (****) Date 08-15-2012 21:15
How about the Yellow Pages?
Parent - - By qcrobert (***) Date 08-15-2012 22:00 Edited 08-15-2012 22:04
Grainger, Sears, Ace Hardware, Harbor Freight, garage sales.....
Grainger page 2458
9 punch set
Item No.3L759
$130.30
Parent - By Stringer (***) Date 08-16-2012 00:11
We do a lot of gaskets, usually custom, where I work, and while the hole punch is great for some applications, we usually reach through the flanges with a die grinder and a coarse aluminum style burr and instant holes that line up perfectly.
Parent - By jwright650 (*****) Date 04-18-2013 19:33
Parent - By FixaLinc (****) Date 04-20-2013 15:55
I just priced & bought these All Pax Corp hollow punch sets and found best prices with Grainger same punches but Mahew name and also in stock at McMaster Carr  www.mcmaster.com
They are not cheap punch sets like many others and stack to make washers also.  Something else you can do is look for a old hole saw with teeth worn out has the right diameter to make a punch from by chucking it in a lathe then grinding a edge on it makes good punch out hard steel.  Guardaire bought out All Pax Corp and when I called they told me Fastenal & Motion Industries were dealers but went into their stores they knew nothing about these punches.  Buy them online or Grainger or McMaster.
http://www.allpaxcorp.com/allpax/productmatrix.html#hollow
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=hollow+punch+set&op=search&Ntt=hollow+punch+set&N=0&GlobalSearch=true&sst=subset
http://www.mcmaster.com/#hollow-punches/=mekmjt
- - By weldwade (***) Date 04-18-2013 20:56
These are the best for rubber. I have punched hundreds of holes in conveyor skirting 1" rubber with them.
http://www.csosborne.com/l-punches_1.htm
The Arch punches from These guys will handle repeated abuse from a big a$$ hammer. The US General punches won't stand up to more than one or two smacks with a 4lb beater.
Parent - By theelee87 (*) Date 04-19-2013 00:10
Thanks for the help and info, I ended up finding a nice used set at an auction awhile back.
