We qualified a procedure for welding of tubular T-,Y-, and K-connections with backing per paragraph 4.13.2 and Table 4.1 in the Qualification chapter of D1.1.
We used a 6.625” nominal OD x 0.250” wall thickness pipe coupon. According to 4.19.3, the welder of a successful procedure test sample is automatically qualified to weld to that procedure. However, the coupon we used to qualify the procedure doesn’t fit within the dimensional parameters of Table 4.11. Therefore, I seemingly have no way to assign thickness and diameter limitations to the welder’s qualification. Am I missing something?
Thanks for your reply.
By 803056
Date 08-27-2012 18:52
Edited 08-28-2012 04:04
D1.1-2010
Review: The welder qualified the procedure using pipe and a standard V-groove with backing. The diameter was 6 inch and the wall was 1/4 inch thick.
Moving to Table 4.11 (2); the welder is qualified 4 inch or larger (tested on larger than 4 inch). Tested on wall equal to or less than 3/8 inch wall thickness, so his range of qualifications is 4 inch diameter or larger, 1/8 inch wall through 3/4 inch wall.
T, Y, and K: The welder is qualified for butt joints in tubulars and PJP in T, Y, and K joints, but no CJP without backing or back gouging. He would be qualified for any prequalified joint detail shown in Figure 3.8 that utilizes a "back up weld" which for the purpose of D1.1 serves a similar function as backing.
The welder is not bound by the limitations on thickness when the WPS is qualified for impact toughness, thus the upper thickness for the welder qualification is 3/4 inch rather than 1/2 inch as is the WPS.
At least that's how I read it.
