The groove detail in figure 4.25 does not specify a groove angle. It simply suggests a 60 degree included angle.
You failed to provided detailed information with regards to the production groove, but if experience is a guide, I would bet someone specified a 45 degree angle for the single bevel groove. There in lies the problem. From table 4.5 item 33 addresses changes in the groove angle, fitup, etc. It would come as no surprise that a single bevel groove could run afoul of item 33.
Were you to qualify the WPS (as you appearently did), you could use any prequalified groove detail as per item 31.
Best regards -Al
Table 4.5 sub 31. A change in groove type(e.g..single-V to double-V), except qualified of any CJP groove weld qualified for any groove detail conforming with the requirements of 3.12 or 3.13
WPS not approve cause 3.13.4 Tubular Butt Joint (2) Nonprequalified Joint Detail. There are no prequalified joint details for CJP groove welds in butt joint make from one side with out backing.
if PQR was single V groove with out backing or back gouge u need to requalified PQR single bevel. unless u PQR qulified with backing or back gouging then can use prequalified joint detail in Figure 3.4 any groove type (single bevel,single v or double v)
if im missing some thing pls advise
Thanks
winai
