hey mike,
the 175 will weld alum. a stiffer wire such as 5356 will feed better than a softer such as 4043. the drive rolls need to be radius type. not knurled or v type. make sure the corners of the u shape and the o.d. of the rolls are smooth. use a new contact tip and run a reamer thru it and be sure there are no burrs. use no larger than .035 wire, reverse polarity (+), argon gas and tilt the gun in the direction of travel (push) with no weaving. make sure everything is totally clean with no shavings and get a teflon liner so you dont have any arcing or wearing inside. the biggest problem is feeding using this type of feeder. dont kink the gun, and try to keep a straight line from gun to welder. also make sure you use a quality wire such as alcotec. they have a great site www.alcotec.com
for welding aluminum. clean the drive rolls with alcohol and make sure your material is properly cleaned. i cant think af anymore to ramble about. good luck, let us know howya make out.
rich
for thin aluminum, I prefer a TIG welder for its controling ability. I'd want a MIG for thicker aluminum because of the deposition rate. and you have to move faster that you would w/ steel of the same thickness w/ a MIG, which would make it kinda hard to move in a circle on thin material without burning through. with a TIG I could just take my time all the way around. have fun!
