Tommy,
Appreciate the tip from Cactus. I remember strange things like that many years ago when I was rigged out on a '91 GMC 3500.
Sometimes setting an independent ground wire from the Welding machine chasis driven into the earth seemed to help. Then, it was always set on the shotgun side of the rig and then you (ME! dingy) forget to pull it when spooling up.
Since you found a cure, I was gonna suggest installing Tweeco lead connectors on your battery cables
, but sounds like Cactus has the preventative "right tool".
