Do you have any existing weld procedures that can be used for reference? Or can you reference a pre-qualified weld procedure? It depends very much on what parameters are selected. I mean, if the heat input can be increased then the travel speed can also be increased. But for an estimate, I would just reference a book of parameter settings such as the Lincoln Prodedure Handbook or one of the Miller books. And then too it is always wise to multiply by 1.5x or 2x when making estimates.
