I don't want to steer you wrong and screw up your machine, so get some more advice too, but I've been welding for 20 yrs and I've done nothing but switch wire. Polarity I don't think has anything to do with it. You may need to change your feed roller, to one with teeth designed to push soft flux cored wire and use a 75-25 mixture of gas. Good Luck!
- Buffalo
Most Gas Shielded Flux core wires run the same current and polarity as GMAW. IF you are speaking of self shielded flux cored wire such a E71T-11 then the polarity would be DCSP as opposed to that used for GMAW (DCRP). Self shielded wires E70T3,4 runs on DCRP.
The common wire for that type of machine is usually 71T11 or GS.
As far as swapping leads. Can't help you.
Have a nice day
Gerald Austin
Iuka Miss.
Thanks for the replies. I'm wanting to use "self shielded" flux cored wire so I don't have to lug my gas bottle around with me when I do stuff in the field (which is usually on thicker material than I weld in my garage).
I'll give Snap-On a call but as far as I can tell its just a case of swopping the cables. If anyone knows for definate then please let me know (I'm not going to do anything unless I get a definitive answer).
Ian
Gerald
Have I miss-read your mail - are you saying that there is a Self shielding wire type (E70T3,4) that uses the same polarity (DCRP) as for GMAW ?
Ian
ask Snap-On... they'll know how to reverse polarity on the machine
regards
d
I'm not sure about your Snap-on machine, but the little Hobart 135's you open the side panel and switch the leads for polarity changes, the lugs are marked so even I can't screw it up.
John Wright
John
I was going to build in some lugs as you have described (and as per the "dual" machine (ie gas and no-gas) I was looking at in Harbour Freight). I'm assuming there is no feedback circuitry in these Migs which would not like a polarity change. Maybe an "electrics" person can advise.
a welding mahcine doesn't care what polarity it is running- electricity will run from negative to positive regardless of which end you are "using" for the torch....you could go ahead and build a couple of lugs to change polarity and not have a problem.
If you run self shielded flux cored wire you will have to operate at a higher heat range to get the same results as when using the shielding gas.
E-xxT-1 through 6 are electrode positive.
E-xxT-7 through 11 are electrode negative.
E-xxT-1,2 & 5 require external shielding gas.
