By Jovi Zhu
Date 11-05-2012 02:38
Edited 11-05-2012 02:43
Jeff,
You are not the only "lost" one having a hard time dealing with Section IX book. Too often, dealing with the detailed wording of this book blocks us from seeing the whole picture.
First of all, Section IX is about welding procedure and performance qualification. Backgouge is an essential variable (for performance) as required by Section IX to be qualified by the manufacturer himself. In other word, Section IX doesn't give you guideline on whether backgouge is needed for your specific application but rules of how to qualify.
Another way to say: Section IX is just a QUALIFICATION standard other than a welding HANDBOOK. See the front cover.
Why is backgouge an essential variable for performance qualification, but not for procedure qualification? Here is the answer:
QW-401.1 Essential Variable (Procedure). A change in a welding condition which will affect the mechanical properties (other than notch toughness) of the weldment (e.g., change in P-Number, welding process, filler metal, electrode, preheat or postweld heat treatment).
QW-401.2 Essential Variable (Performance). A change in a welding condition which will affect the ability of a welder to deposit sound weld metal (such as a change in welding process, deletion of backing, electrode, F-Number, technique, etc.).
That is to say, the ASME Section IX Committee believes that backgouge doesn't matter very much to the ABILITY of the Procedure to make weldment of acceptable mechanical properties, but it does matter a lot to the ABILITY of the Welder to deposit sound weld metal.
With the application of backgouge, a welder can have a good time making a sound weld metal. But without it, he may have a hard one.
Your lead welder was giving a good suggestion on how to easily make the weld metal sound. If other product configuration of yours make the backgouge impractical, you will need to find other ways(e.g. to qualify a welder without backgouge).
Thanks,
Jovi
