Up Topic Welding Industry / Processes / Corrosion test methods for Braze
- By CMeinhardt Date 11-07-2012 20:27
I am a chemist working in with electroplating solutions.  I perform a corrosion test method using ASTM B117.  Do you know of a corrosion test method or corrosion test specification from ASTM or AWS that tests for corrosion braze on SS?  I was told none exists and I’m sure there has to be something out there.  Any leads would help.  Thank you.
