Up Topic American Welding Society Services / Technical Standards & Publications / Question on AWS D1.1 Figure 5.2 End return of access hole
- - By allenliao (*) Date 11-15-2012 07:38
Gents,
Why does the AWS D1.1 Code specify the end return is not made if the access hole is made before welding web to flange?
Please refer to "note c" Figure 5.2 Weld access hole geometry.
Many thanks.
Parent - By S. WINAI (**) Date 11-15-2012 14:50
Allen,
My opinion that.  Note C is a fillet weld shape.  General welding sequence. Flange joint should be weld  first before  welding  on web to flange corner end.
This is just my own idea. I also still confusing why code have to mention that!
Winai
Parent - By jwright650 (*****) Date 11-15-2012 15:07
I think the idea is to cut that access hole in the web before putting the flanges on(built up shape made out of plate)....and idea of not wrapping the end with weld may have to do with the possibilty of creating a notch in the web when welding around that end.
