Hello All, first post here for me. Been searching for an answer to my question and stumbled on this site.
I'm registered for an AWS Section VIII endorsement exam in a few months. Does anyone know the Body of Knowledge for the Section VIII exam? I'm sure the exam isn't over the entire book and would like to focus my efforts on what will apply to the exam. All AWS has or knows is what's printed which is no break down, Just Sec. VIII and Sec. IX.
There are many CWIs that work with employers or clients engaged in fabricating to AWS, ASME, API, ABS, NAVSEA, and other military welding standards. Whether the code requires or recognizes the CWI certification isn't the question. The question is whether the CWI has a working knowledge of the welding/fabrication standard used by the employer or the client.
One of the comments often heard from employers and clients is whether a CWI is familiar with a specific welding/fabrication standard. The endorsement offers a vehicle whereby the CWI can demonstrate his familiarity with a specific welding standard and provides documented evidence that an examination has been successfully passed. It is an examination offered by an internationally recognized professional society.
The endorsements are not mandated by any welding code, AWS D1.X included, but is increasingly requested by potential employers looking to hire qualified inspectors and customers seeking a third party inspection agency with qualified people to perform QC/QA functions.
The additional benefit of an endorsement is that it is one additional means of fulfilling the 9 year recertification requirement. The endorsements are an option permitted by QC1 allowing a CWI to meet the requirements of the 9 year recertification. It is easier for many CWIs to take an endorsement examination rather than acquire 80 PDHs or retaking the Part B Practical Examination to meet the recertification requirements.
If an endorsement isn't something an existing CWI wants or needs, there is no one twisting their arm to take an endorsement examination.
I, for one, use my endorsements as a marketing tool to separate myself from the rest of the herd. It seems to be working. I sell my services based on my demonstrated expertise rather than (low) price. Clients that are looking for the lowest price have to look elsewhere. My endorsements are just additional credentials I show to prospective clients.
I guess it is a case of saying "I'm the best" versus showing the client you have attained a level of expertise.
ede,
As everyone has stated according to ASME, the endosement is basically useless, however it may be a good marketing tool. You may be better served by taking a couple of the National Board online courses which upon sucessful completion they will issue you a certificate. The below course is a good one for someone who wants to show they hve knowledge of section VIII and it is all for $150.00. Even though it is tailored to the "UM" requirements, it still covers most of the basic fundamentals of Section VIII. I have had all of the QC inspectors that work for me take this course just to gain additional familiarity with Section VIII. You can go to www.nationalboard.org to see all of their couse offerings.
Hope this helps.
Certified Individual: Unfired Miniature Pressure Vessels, is an online course covering ASME Section VIII, Div. 1, Rules for Construction of Pressure Vessels.
This course has been prepared for ASME "UM" certificate holders in preparing their employees for designation as Certified Individuals. The focus is on the Certified Individual's responsibilities, duties, and ASME Boiler and Pressure Vessel Code requirements applicable to unfired miniature pressure vessel manufacturers.
Although this course is designed for the Certified Individual, anyone involved with unfired miniature pressure vessel construction and inspection may benefit from this training.
Students will need to obtain their own copy of ASME Section VIII, Div. 1 to use as a reference, and to follow along with the course material. Note: ASME Code Books may be ordered through the ASME Web site.
Working straight through the material, it is estimated the course takes approximately four hours to complete.
What Is Covered
The course curriculum comprises the following:
Section VIII, Div. 1: Introduction
Scope
General
Subsection A: General Requirements
Part UG: General Requirements for All Methods of Construction and All Materials
Subsection B: Requirements Pertaining to Methods of Fabrication of Pressure Vessels Requirements for Pressure Vessels Fabricated by:
Part UW: Welding
Part UF: Forging
Part UB: Brazing
Subsection C: Requirements Pertaining to Class of Materials Requirements for Pressure Vessels Constructed of:
Part UCF: Carbon and Low Alloy Steels
Part UNF: Nonferrous Materials
Part UHA: High Alloy Steel
Learning Outcomes
After completing this course, students will be able to:
locate key information in the ASME Boiler and Pressure Vessel Code, Section VIII Div. 1, that relates to unfired miniature pressure vessels;
identify the main duties of a Certified Individual; and
describe the purpose of the ASME form related to unfired miniature pressure vessels and determine when it should be used.
Reference Materials
Each student is required to have the following materials (currently mandated edition):
Criteria for Successful Completion
As a minimum, for a National Board Certificate of Completion to be issued, students must:
actively participate in all online course interactions
responding to all knowledge check questions
achieve a passing score of 70% or higher on the final assessment
complete the course evaluation survey
