Hi John!
MERRY CHRISTMAS TO EVERYBODY IN HERE AND OUT THERE!!!I think we're on to something from this old thread you linked in your post...
I remember that thread and I had a hunch beforehand that it have something to do with what the OP in his third post mentioned regarding the burning of any residual oils left on the members would be burned off by the preheat... Here's what I'm talking about;
"As far as the parts being clean, all rust, mill scale, etc is removed prior to fit up and with the high preheat that we have all oils from the milliing is burned away."And then I read this in the older thread you posted;
" XPERTFAB Date 01-16-2007 21:12
Blaster,
Add one more parameter to you list of havoc wreaking situations for the FCAW wires mentioned. That is the residue remaining from the sawing and machine coolants used in the fabrication process of components to be welded." The red flags went up and then again, this is only one of he many possibilities which can only be verified @ the site where the welding is being performed...
So, without actually witnessing every step in prep, while welding is being performed, one cannot guess this problem you have especially if it only comes up;
"This is not an issue that we encounter all the time (one out of every few months)" only once in a while.
