Up Topic Welding Industry / Inspection & Qualification / ASME VIII DIV II 2007 Pressure Gages
- - By maxilimiano (**) Date 12-20-2012 08:16
Dear All...
Can anyone interpret this statemen in par 8.4.1.c "Dial indicating pressure gages used in testing shall be graduated over a range of about two times the
maximum intended test pressure, but in no case shall the range be less than one and one-half times nor
more than four times the intended test pressure."
Thank b4
Regard
Parent - By fschweighardt (***) Date 12-20-2012 12:24
If your test pressure is 100 psi your test gauge should be ~ a 200 psi gauge.  No more than 400, no less than 150.
Parent - By G.S.Crisi (****) Date 12-28-2012 19:43
This is because the precision of dial pressure gages, that have a Bourdon tube inside as the pressure sensitive device, is better between 25% and 75% of the full measuring range. Indications under or above these limits don't deserve full confidence.
Digital pressure gages don't have this limitation.
