Thanks Tommy...I'll try to do some additional troubleshooting with my meter on the lil machine and see if that lil relay is the culprit. I haven't opened the case yet, I was assuming it had a set of contactors that pulled in when the trigger closed. I laid a screwdriver across the terminals where the trigger wires plug into the back of the board on the "door side" of the cabinent(nothing happened, no wire feed)....like I stated, I haven't opened up the box yet. I expect the relay didn't like the triggering to tack that sheetmetal to the door frame of my garage.
Post up a link where you found that relay, if you think about it later.
