If you are going proceed as you suggest, my counsel would be to insure that the Welder Qualification Test Report was generated in such a way that your stamp/signature was placed in specific boxes that represented EXACTLY the inspection steps you participated in ALONE.
D1.1 Annex has examples
I don't see anything out of order if an outside party performs things like.. Bends, RT, Tensiles, etc. As long as each of those tasks have a specific area in the form for sign off approval/Fail.
If you are not going to wittness the test, it is impossible for you to verify that the WPS was followed. So somebody else needs to sign off on that compliance area and the form really should be clear as to who did what.
I would be more than hesitant to sign off as a qualifier if I wasn't a wittness to the test.
It's an easier matter to sign off for simply performing specific inspection duities on a coupon.
