Up Topic Welding Industry / General Welding Discussion / 200d ammeter
- - By sjkelly328 (**) Date 01-22-2013 02:12
I have a 2007 200d and my ammeter while the machine is running is at +40. I am trying to figure out what the problem is and would like any help I could get. I have checked the wire feeding the ammeter from the alternator, and it is reading 14.5 volts. What else should I check.
Parent - - By DaveBoyer (*****) Date 01-22-2013 20:12
First verify the amperage with another ammeter, even the kind that clamps on the alternator wire is good enough for this test. Repeat test on battery cable, should be close to the same.
If there is  40 amps [or anywhere near that much] going to the battery, the battery is probably nearly shot, substitute a known good battery, and see if amperage drops to an acceptable level.
Finally, 14.5 volts is too high for a continuous chasrge, check with a known accurate volt meeter.
Contiouous charging voltage should be below 13.5, better 13.2-13.3 to keep from boiling all the water out of the battery.
Parent - - By sjkelly328 (**) Date 01-23-2013 12:23
How could you check the ammeter to see if it is bad?
Parent - - By DaveBoyer (*****) Date 01-24-2013 01:23
Measure the amperage with an ammeter known to be accurate, and compare the readings.
Parent - By sjkelly328 (**) Date 01-24-2013 03:16
thanks for the help, I have diagnosed the a meter to be bad.
