I am not that creative but in my mind I am seeing a table with adjustable jaws that are similar to a vertical lathe bed. THe jaws wouldn’t touch the ID or OD. These jaws would be adjustable and only touch the face on the bottom of the ring. I am envisioning an “L” shaped jaw with the vertical part of the jaw on the center that would be on the ID of the ring in 4 places that adjust in and out from the center location, again similar to jaws on a vertical lathe.
Maybe take a lift table and add a round plate that can add the adjustable jaws and a drive system.
I talked to some of our sales people and they don’t quote rings that require more than 75” ODs. So looks like a max 75” is only necessary and that will drop the weight MAX down to about 2500lbs.
I could possibly use a static table but if we are spending this kind of money I would like to do it the most efficient way with the most options possible. My problem with the static table is I don’t want to have to walk around it while tripping over the table or getting dizzy
Doing UT isn’t that bad but doing solvent removable PT I go around and around wiping and more wiping, blah, blah, blah.
