Up Topic Welders and Inspectors / Welding Equipment Classifieds / postioner
- - By weaver (***) Date 01-25-2013 13:35
looking for a postioner, that can handle 3500lbs for with 135deg working radius
Parent - By cmays (***) Date 02-19-2013 04:42
Mitrowski welding supply in Houston, Tx. Check with them ovation ally they have some good reasonable refurbished units. If its new you want, they have always had what we need. Also check out Alfab corp. I'm not sure what you're doing but I have bought positioners and rollers from both with no problems. Hope this helps.
Parent - By JeremyW83 (***) Date 03-13-2013 00:21
Might also try Red-D-Arc.  I know they sell old machines might have positioned as well.
Parent - By Dennis Camp Date 09-24-2013 12:35
If you did not find a positioner you may want to try Weld Plus positioners in Cincinnati. They have new, used and rebuilt positioners in stock.
It will save you freight as compared to buying out of Texas.
