We will use HDPE ( High density polyethylene ) pipes as liner ( max. operating pressure for the liner itself is 25 bar ) inside carbon steel pipes as host pipe ( which work in 100 bar )
the technique will be used is tight liner which Ensures perfect adhesion pipe liner and host pipe
the question now is the high pressure will affect the pipe liner or not
best regards
