Right you are Shane, two different things.
What you are talking about, up-slope and down-slope is a feature that some machines have to enhance the welding experience (market talk). However, to complicate issues even more, some programmable machines can change the slope of the pulse when using pulse mode. To make matters worse, some GMAW pulse programs actually utilize variable slope, i.e., constant current versus constant voltage, while pulsing.
The traditional constant voltage power supply maintains constant voltage as the welder varies the wire feed speed and/or contact tip to work distance. However, some pulse programs utilize constant current depending on the particulars of the manufacturer's program. In the latter case, the voltage can experience considerable variation as the welder varies the contact to work distance. It can catch the user off guard because the machine does not respond as expected. Add in the complexity of up-slope and down-slope, frequency, pulse width, variable inductance, etc. and one can easily see where programing these machines can be very frustrating to the average welder.
I’ve said it before and I’ll keep saying it, there are many situations where people get sold by sales people on the idea that pulsing is the best thing since sliced bread. I have been involved in too many cases where the customer would have been much further ahead if they had simply stayed with the traditional GMAW power supply. Pulsing is oversold. Only the sales people and the power supply manufacturer come out ahead in that game. To add icing to the cake, the fabricator becomes dependent on the power supply manufacturer to provide a new program when the materials change.
Qualifying WPSs using pulsing power sources is ridiculous. There is no way one can “record” the welding parameters without a multichannel oscilloscope. Once qualified, there is no way that WPS can be used with a different model power supply even if it is from the same manufacturer. Enough of a rant, you’ve heard it before.
