Hi Alen
I am not an expert at this (I am not a welder.) but from my training days, I can remember the following:
1) Weld vertical up.
2) Do not weave the root. Rather hold the arc in the centre of the weld line.
3) Hold the wire feeding into the puddle just below where the gap is visible. If you try to hold it higher (pointing up) the wire will just shoot through gap resulting in pieces of wire sticking out on the inside of the weld.
The volts and wire feed speed settings should be available from the supplier. If you do not come right ask again, and I will haul out my procedure books to look up these parameters for you.
Niekie Jooste
Alax, first of all good luck. I have welded a lot of pipe, and more FCAW than I want to remember, but never put the two together. This does not mean that it is not done. Anyway, you will be very busy compared to he other two processes mentioned. You did not relate to metal type or test position. So, one would probably guess, steel, perhaps sch. 80, 6G position or 6GR, Probably E71T-1, CO2 gas. Now all you have to do is be a good MIG welder. Niekie is correct with the paramiters for they should provide you with a WPS, and if not, ASK!! To continue guessing, you should fit-up as normal, gap and landing according to wire size. You will probably remain in short circuit transfer, so run it like you would any mig application. If all of this is wrong forgive me. If need be, e-mail for number and I will walk you through it. Wesley.
You should be careful to not allow the wire to touch the sides of the bevel. With FCAW, the puddle has a tendency to bridge over a slag line if the wire touches the bevel wall. Once this "bridging" gets stated it will continue to do so for the length of the bead, leaving a slag line underneath the bead. Watch the leading edge of the puddle closely. It should be sharp and convex. If it becomes concave, you'll know that it is trapping slag underneath. If this happens, you'll have to grind it out back to the point from which the wire first touched the bevel wall.
The fit up should be as per the WPS requirments.
Good Luck!
Tim
