Up Topic Welding Industry / Inspection & Qualification / diameter tolerances
- - By sciroccos1111 (*) Date 03-02-2013 20:04
Hellow everybody,
i have a problem about the diameters of 30'' pipe and elbows with seam. They are not circle but they have an oval shape. In with section of ASME am i going to find the tolerances to know which fittings am i going to reject
Parent - By 803056 (*****) Date 03-03-2013 13:55
Check the base metal specification, i.e., ASTM A53, ASTM A106 for carbon steel pipe, ASTM A312 for stainless pipe, etc.
The construction code; ASME B31.3, B31.1, etc. may provide some additional guidance.
Parent - By Joey (***) Date 03-04-2013 07:37
Out-of-roundness ; you get the difference between the max and min inside diameters at any cross section, the difference should not exceed 1% of the nominal diameter at the cross section.
But how will it pass the dimensional check when you can visually confirm the pipe is in "oval shape". Surely, there will have a misalignment during fit-up assembly.
~Joey~
Parent - By G.S.Crisi (****) Date 03-04-2013 22:44
As Joey said, the out of roundness tolerance is 1% of the nominal diameter. For a 30 inches (762 mm) diameter, the tolerance will be 7,6 mm, more than 1/4 of an inch.
You don't need to reject anything. Using strongbacks and wedges you'll drive up the two ends until they face perfectly each other and the joint can be welded.
In the case of pipe and elbows, the pipe is the weakest piece and it will conform to fit the elbow shape.
Parent - - By maxilimiano (**) Date 03-06-2013 12:10
Hello brother,
you can reject that by "missalignment". because of that shape, you will get difficulty to weld with normal pipe.
regards
Parent - - By G.S.Crisi (****) Date 03-07-2013 22:51
Max,
The standards to which the pipes are made (A 53, A 106, API 5L, etc.) allow an out of roundness  of 1%. This means nothing in a 2 inches pipe, but means a great deal in a 30 inches pipe, as the one we're talking about. As I said in my first posting, it means that the out of roundness may be 7,6 millimeters, more than 1/4 of an inch.
If  scirocco's 30 inches pipe shows an out of roundness of, say, 7,5 millimeters, it can not be rejected because it is within standard. What he (scirocco) should do is to employ the usual strongbacks and wedges to match the two pipe ends, and then weld them.
Parent - By WELDICCAWSCWI (**) Date 03-08-2013 05:13
dearman clsamps and the heavy steel basket clamps will work wonders .you weld a a dog on a pipeline
its anm automatic cutout  weld outside weld groove,. so calif gas requires backwelding on all pipe fittings over 12" due to
mis,match between pipe and fittings
- - By erfannehmet Date 06-05-2013 16:33
Actually I have struggled to measure radial offset (high-low) in spiral pipe. So, I have attached a picture which shows two method for radial offset measuring which is consist of parallel to pipe centerline and vertical to that. Please guide me to select the best method.
Parent - By jwright650 (*****) Date 06-05-2013 18:00
I left this question in place, but in the future, would you be so kind as to start your own thread and ask a question, vs asking the same question in multiple threads all over the board.
Thanks
