Guys,
Thanks very much for the replies, a lot of usefull information. I'd like to leave a few responses to your input. As to photos, sorry, can't bring myself to do it. The pretty little railings look nice, smooth, straight, square, level. plumb and to grade, but the cracking is HORRIBLE. Imagine a smack with the Ugly Stick to a pretty face and you've got the picture. Really heartsick about it, seeing good work marred up. Giovanni, you are correct, The American Concrete Institue would be the forum, I had already looked them up in hopes of speaking with an engineer to get some insight and maybe a better determination of root cause, called the main office and was refered to a local chapter phone line that didn't pick up. Seems like a membership with them may be required to access anything valuable but I will be pursuing it. As to the grout used, the cut sheets for the product were submitted and approved, Sakrete, and what was used, but suggestions for an alternative to use in the future is appreciated. The next big project just getting started is a DOT railing job, 2080 LF, posts every 5'. The contract documents were typical bueracratic, unreviewed, rubber stamped, insert incorrect specification here, and cross reference it elswhere with something different. The plans on this one call out Epoxy Resin [Big Dollar Stuff] on one sheet, Epoxy Grout on another sheet, and the Special Provisions specify Epoxy Grout [Real Spendy] and then gives a spec number for a Type IV Multipurpose non-shrink mortar grout, the normal stuff. Guess which one got used for bid? Yup. Go to the Qualified Product List, the DOT webpage listing of approved products, pull up the Hilti product that's been approved and use it during original pre-con meeting, then submit it with shop drawings and it gets approved. One large difference is the DOT job will be using sleeves set in the concrete, I provide/GC places, and the railing is embedded using grout in those. My gut tells me that is a far less dangerous path to tread in regards cracks. The sleeves should provide sufficient expansion while the concrete cures and setting the rails after that will pose less risk.
Smooth, very much like the partially filled grout option with a sealer cover, I'm sure it give a very nice finished look. Problem with guvmint work would be getting approval. It would require extensive engineering submittals, out of my pocket, and even then an act of congress or a revision of all Calculus assumptions to get it approved. DOT engineers are VERY careful about exposing their well paid positions to unknown factors. Which is, I suppose as it should be. They build our bridges, we want them to be carefull and know what they are doing, and they're spending our money so we have a right to get what we paid for even when it's just some pedestrian railing that needs to be set in place and take a 50# concentrated load. The process can get a little irritating, what with the endless daisy chain of emails sorting out the most picyune details, or needing to explain to qualified engineers something as basic as a geometric impossibity [think 10# of dung in a 5# box], they get it finally and see the light and things move forward, but at a snails pace. So it can be frustrating. In the end though, when I've had a chance to communicate directly with any of them, and cut through some of the red tape or protocol which causes so much confusion, they have all been great guys, smart, easy going, practical and mostly with real good senses of humor. Ain't met a miserable one yet in the bunch.
Finishing up some refrigeration piping this week and just got home with the Crack Issue weighing heavally on my mind all day and talked with the insurance agent. Turned out to be very reassuring. The product completion liablilty on my insurance is there for exactly this kind of occurence. Should it come to a lawsuit, the insurance company sends in the lawyers! Hot Damn! At least that potential money drain aint gonna bleed me dry this week. Really took some weight off. Beyond that, every single concrete contractor/ core drilling-cutting contractor I've spoken with [now counting 6] has told me the same thing- It ain't my fault. Further, they've all said the same thing: the plans called out a 3" core, 3" off the edge of concrete, leaving a 1 1/2" critical edge distance and that's too close, cracking was going to occur. At a pre-con on that job, I reccomended sleeving the holes to the architect and he wouldn't have it. Questioned the coring schedule to be done in less than a 28 day full cure and was told the concrete was good to go. Used the stuff they approved, Sakrete, and now getting questioned on it with bad juju liabilities hanging around. Sometimes this racket just feels like a warzone.
Maybe I worry too much. I like to think it's just being concientious. Cover all the bases, make sure everyone knows the risks and whats up. Piss of GCs and project managers with details they don't want to bothered with trying to keep them from coming back to bite them or me. Thankless bastards some of them. The good ones, get you paid on time, express a token of appreciation for the save their ass value added engineering you suggest that saves them 10 grand or 20 in manhours or warranty work seem a little far between tonight. The smug bastard making trouble with me now is no one I trust, so I'm not counting chickens or thinking I'm out of the woods, just gonna keep on keepin on. Only thing I'm sure of tonight is you gotta be able to look a man in the eye and know you did the right thing. Like that guy said, "It's a good life if you don't weaken".
Thanks for letting me vent fellas.
