Man! Do you open up a full can of questions with your query! I say this because you leave out application, base metal alloy designation, thickness, preparation for welding, any out of position welding? Shielding gas, welding out put parameters although you did mention the methods of transfer... Joint configuration, what standard/code are you working to... What is the size of the assembly, does it require you to have more than a 25 ft. reach to deposit the welds? Any Post Weld Heat Treatment (PWHT), anodizing? In other words, as much pertinent details that you can post so that we could give you some recommendations, suggestions...
Btw, those model wire feeders are not a popular model with this crowd because most folks in here use either Lincoln or Miller brand feeders...
Even though there's not enough info regarding your application, I would suggest a push-pull system if the welding is to be deposited more than 25 ft.from the wire feeder and/or you will be depositing a whole lot of weld using a soft Aluminum wire like 4043... I don't remember if ESAB sells one but, I know MK products & Lincoln Electric do have various models and both work pretty good although I give preference to MK because they're the folks who have had their push-pull systems copied by everyone else so that should tell you something. Someone else will chime I'm sure.
![lol :lol:](/f2/epx.png)
And I'm sure some will disagree with my preferences... Oh well, can't please everyone.
![wink :wink:](/f2/epx.png)
