By Cumminsguy71
Date 03-20-2013 21:54
Edited 03-20-2013 21:57
That tower I welded on the engineer specified on the prints that the material we were adding would most likely have "gaps". For gaps up to a certain size he increased the size of the weld by 50% according to gap size. For other gaps he called out using a filler material, "A36 or equivalent" to fill the gap and increase the weld size accordingly. The CWI report the CWI has called out the gaps and he has raised questions about the size of the gaps(1/4", also noted on engineered drawings and welded as per engineered drawings) and recommended that we contact the EOR. Hmmm, apparently he can read welds but not prints.
Depending on what your doing you might want to make sure that everybody is on the same page. On our project as I said the weld size was increased by 50%, 1/8" gap, 1/4" weld, 1/4" gap, filler metal and 1/2" weld.
