Assuming this not for a commercial application.
What kind of pointers are you looking for? What process and filler will you be using?
The most common PWHT for 4130 would be 1050 deg F / 1 hr. per inch of max cross section.
PWHT effects the strength of the weld joint, do you know for sure thats what you want to do?
