That may be so but, it certainly doesn't look like something I would purchase because there's no weld to join the web of each piece together and I would at the very least insist on that before approving it if I were the customer then again, that's just me...
If I might add, would you be so kind to show us a better picture of the weld to the pipe that attaches the pipe shoe design? Also what if any amount of vibration will this pipe shoe be exposed to... And are the beams & the welds going to be painted or coated with some sort of corrosion protection if this is going to be exposed to a moisture rich environment?
