NEW E-COURSE HIGHLIGHTS WELD DISCONTINUITIES AND DEFECTS
Hobart Institute of Welding Technology just released the latest in a line-up of online courses. Discontinuities and Defects concentrates on identifying and defining various types of discontinuities and defects to determine the common causes of those welding problems.
The online course contains 5 video segments totaling a run time of 70 minutes. These segments cover:
• Weld inspector responsibilities related to discontinuities and defects
• Identification & definition of weld discontinuities & defects
• Common causes of discontinuities related to shape, size and contour
• Common causes of discontinuities related to internal inconsistencies
and weld metal irregularities
• Common causes of discontinuities related to weld & base metal properties
Technical Instructor Russ Shurtz developed this course for Hobart Institute and says, “This course is intended to assist anyone involved in arc welding inspection, quality control, engineering, or supervision.”
At your own pace from your computer you will view videos and will be able to take an online review test for each video section.
At the conclusion of the 5 video topics you will take a final test. When you score 76% or higher, a Certificate of Completion will be issued for you to print that will contain the 1.0 continuing education units earned for the online course.
Take the Discontinuities and Defects E-Course today at
http://www.welding.org/c-54-e-courses.aspx ABOUT HOBART INSTITUTE OF WELDING TECHNOLOGY
Hobart Institute of Welding Technology, dedicated to welding training and education excellence, is a 501 (c) 3 nonproftt educational facility located at 400 Trade Square East, Troy, OH 45373. Phone: 1-800-332-9448. hiwt@welding.org .
http://www.welding.org.
