Hi Strat
It looks to me like your pipe does not meet the material specification requirements, but is suitable for your application. All you need to do is make sure that the designer specifies the material in terms of the minimum wall thickness, rather than a nominal pipe size. One has to be careful here, because some client specifications may specify a minimum thickness, irrespective of what the design calculations say, hence the possibility that the thicker shell is called for. Also, the designer may ask for a thicker shell so that compensation is not required for nozzles. - Bottom line is that the designer needs to specify the minimum required thickness, rather than a nominal pipe size, then all will be clear.
Hope that helps.
Niekie
By MBSims
Date 04-28-2013 01:03
Edited 04-28-2013 01:06
Clearly you can use the 0.403" wall pipe. If you calculated a Code-required minimum wall thickness of 0.057" with no corrosion allowance and intend to use a pipe material that has a manufacturing tolerance of 12.5%, then the minimum required wall thickness with manufacturing tolerance would be 0.057 divided by (1 minus 0.125 or 0.875), which is 0.066". If there is a corrosion allowance, it would be added to the 0.057" then divide the result by 0.875. Always round up to the next significant digit on this type of calculation. Since 0.403" is greater than 0.066", the pipe is acceptable.
Since the drawing specifies Schedule XH, you would need the engineer to accept the out of tolerance material. This could be documented on a nonconformance report with engineer disposition or on an RFI.
