I created this Excel Chart so that my painter can take his readings straight from the sling pschrometer and his surface temperature thermometer and plug them right in and determine quickly if the Surface Temperture is 5° or more above the Dew Point. If the conditions are favorable for Painting the chart tells the painter that it is "OK to Paint", and if not, it tells him "Not OK to Paint".
Maybe someone here will find it useful. I sat down for several hours one day and keyed in the Relative Humidity and Dew Point data from charts.(Sheets are named RH_Table and DP_Table).
All of the formulas and non-relavant cells are locked so that my painter can't accidentally type over them. However if you find an error and need to edit the tables or something, the PW is "paint".
