Up Topic Welding Industry / General Welding Discussion / Any Paint Ijnspetors Hear??
- - By eekpod (****) Date 05-02-2013 17:53
I need a second opinion, my brain isn't working today.
I have a customer requirement that the final DFT for this primer is to be .0006 to .003 inches.
My DFT gauge is reading from 3.1 to a high of 4.0.
How do I convert from mils to inches?
Is it just sliding the decimal point over?
Thanks
Chris
Parent - - By OBEWAN (***) Date 05-02-2013 18:07 Edited 05-02-2013 18:25
Your device would have to be reading in mils I think.  I used to do conversions from microns.  Just Google for the conversions, or look in any paint spec.  It is usually just a decimal point shift, but you need to know the units for your device first.  In machine tool speak, 1 mil is equal to .001".  In the electrical world it might be different, because there are units called circular mils which apply to wire diameters.
Update: I was able to confirm that 1 mil of paint thickness is equal to .001".  (I thought so.)
Here is just one resource for calculations that I found.  I am sure there are many more.
http://www.geionline.com/wet-film-formulae
Parent - - By jwright650 (*****) Date 05-02-2013 19:12
Obewan is right....1 mil = .001",<--one thousandth of an inch
Parent - By eekpod (****) Date 05-02-2013 20:35
ok so then 3 mils equals .003 so I'm good on the low end and a little high at .004.
thanks
