Up Topic Welding Industry / Technical Discussions / Dissimilar metal WPS
- - By farmin72 (*) Date 05-30-2013 15:44
Im possibly going to need a weld procedure for S/S to C/S.  Which AWS code would i need to use for that welding procedure?  Im not to familiar with this.  Thanks for your help.
Parent - By 803056 (*****) Date 05-30-2013 16:03
Contact the Engineer to see which code he wants you to qualify to.
Parent - By jwright650 (*****) Date 05-30-2013 16:32
Not knowing any specifics, I could make a guess that the code may be AWS D1.6, but it would be only a guess.
Parent - By Ehsan (*) Date 06-06-2013 15:18
Farmin,
If you are looking for a document to exactly tell you how to weld them together, I think it'd be better e to search in handbooks or references in the library. You know there's no standard to tell you what to do, it just tells you how to do.
Regards,
Ehsan
- - By 803056 (*****) Date 06-06-2013 16:08
John's suggestion of using D1.6 has an advantage of requiring no volumetric examination of the test weld. Fillet welds must be qualified separately from the groove weld, but the groove weld is required to verify the mechanical properties.
Still, it is the Owner's responsibility to state what welding standard is to be used. Usually, that responsibility is delegated by the Owner to the Engineer when the application is structural.
When in doubt, ask the customer.
Parent - By weldktm Date 06-07-2013 10:52
for some guides relating to the welding parameters, you could have a look at this link:
http://www.weldinguide.com/viewtopic.php?f=5&t=32
