This is a great suggestion to pass the test, but unless it's indicative of the fabrication conditions, it's also a great way to find out you have a cracking problem in production.
Thanks to all for your replies.
My suspicion for the cracking was excess heat input, compounded with no root opening to allow for contraction.
There was no restraint on the test plates, they were simply lying free on a table.
However, I've found that sheilding gas may have been a contributing factor.
After I made the initial post, I checked the equipment and found that the gas regulating flow nut that we use to set the gas CFH from our manifold,
( 90/10 shielding manifold at 85 psi, reduced to 42 cfh by an orifice type flow nut)
had not been removed from the gas line when the 100% argon cylinder with flow meter had been installed.
I believe this limited the sheilding gas flow to less than optimum.
After the flow nut had been removed, I tried to replicate the cracking with all parameters the same except for gas pressure, but was unable to.
My intent is to qualify procedures for:
GMAW-P, CJP of 6061 thicknesses 1/8" thru 1/2", using 4043 filler.
GTAW, CJP of 6061 thicknesses 16 ga thru 3/16", using 4043 filler.
GTAW, CJP of 5052 thicknesses 18 ga thru 1/8", using 5356 filler.
I intend to set a max interpass temp of 250 F.
If anyone has some good advice for me, I would appreciate your input.
Thanks,
Tim Gary
