And other "weird" metals (Inconel, Hastelloy, etc)? I'm assuming there is, yet I can't seem to find any information about it.
By welderbrent
Date 06-01-2013 20:42
Edited 06-01-2013 20:46
As for the Titanium: D1.9- Structural Welding Code- Titanium.
And yes, Clause 3 deals with WPS's and Welder Qualification.
Other alloys, it all depends upon their usage and applicable codes. If they are being used within D1.1 then a PQR would be in order.
Have a Great Day, Brent
Hi
The first question is the application of the product. Once you have that, the relevant "code" will become more apparent e.g:
- Pressure vessel = ASME VIII = ASME IX welding
- Piping = ASME B31.3 = ASME IX welding
- Structural = AWS D1.9
Obviously there will be others depending on the relevant product and industry and country you are operating in.
Niekie
In addition to the various industry codes there are many proprietary company or project specific standards for welding titanium.
I recently worked on an Exxon project and we used a special spec created by Exxon that was dedicated only to titanium.
Titanium is especially sensitive to oxidation, so that would be the main difference between different Ti welding specs. Some customers want ultra-sensitive PPM oxygen monitors and even chamber only welding.
There are sometimes different color standards which control the level of oxidation for the completed weldment. It really depends on the application how strict the controls are. It would not be wise to recommend one catch all spec for this material since each project will have its own unique requirements.
There are many different welding standards that include titanium as one of the many of base metals covered by that standard. A few that come to mind include:
AWS D17.1
NAVSEA S9074-AQ-GIB-010/248 and 278
AWS D1.9
Each standard delineates what tests must be performed to become qualified. Each welding standard may have slight variations from the others, so qualification to one standard rarely is transferable to one of the others.
Best regards – Al
