Up Topic American Welding Society Services / Technical Standards & Publications / Root opening and its Tolerances (Figure3.3)
- - By allenliao (*) Date 06-20-2013 14:15
Hi All,
I feel a bit puzzled by the Values of Root opening and its two tolerances (i.e. as detailed and as fit-up) in Figure 3.3 of D1.1. Can anyone be so kind to explain more detailed?
For example of my question
What is the maximum acceptable root opening dimensions as detailed, available to designer for Joint configuration B-P1a?Is it 3/16(1/16+1/16+1/16) or 1/8(1/16+1/16) without plusing 1/16 of as fit-up?
Many thanks
Allen.
Parent - By eekpod (****) Date 06-21-2013 11:31
ahhh many many times that question has been asked and answered on this forum.
Please try a quick search on the link above and you should find plenty of info, if not come back and we can clarify.
Good luck
Parent - By Milton Gravitt (***) Date 06-27-2013 14:48
Hi Allen, If you have D1.1 2010 you can go to clause 5.22 and it may help you.
                                   M.G.
