I agree it is confusing.
A decrease in lap length is an essential variable per QB-408.4, but within the brackets it says the lap length can be increased without limit. I understand that a decrease in lap length is accompanied by a decrease in joint efficiency, i.e., strength, but it is more difficult to distribute the filler metal as the length of the lap is increased. However, that is only true if you are using the face feed method of introducing the filler metal.
I cannot speak for the committee, but I suppose you could say that the minimum length of lap qualified must develop the required joint efficiency. Any increase in lap length is not going to diminish the joint efficiency even if there is no bond developed in the excess length. To say it a different way, if a procedure using a ½ inch lap length is sufficient to develop the joint strength, it doesn’t matter if the lap is increased to 5 inches as long as at least ½ inch of the lap length is bonded. Even if 4 ½ inches of the 5 inch lap has no bond, the joint efficient is still met by the ½ inch of bond that is present.
Remember in the case of ASME the object of qualifying a WPS or BPS is to verify the mechanical properties, i.e., joint strength, can be met. In the aforementioned example, ½ inch of bond was all that is necessary to develop the joint strength. The purpose of qualifying the procedure has very little to do with assessing the welder or brazer’s skills or whether the procedure can be used in a production setting.
Welcome to ASME. This is no different than a WPS qualified for welding. It is entirely possible to qualify a WPS that cannot be used for production. There is the presumption by ASME that the user is knowledgeable with regards to welding, brazing, design, etc.
I always hang my hat on the fact that the code specifies the minimum requirements that have to be met. It is incumbent on the contractor to take any additional steps necessary to insure the product produced will meet the quality requirements and service requirements.
