good afternoon everyone, I had this problem please someone who is faced with this situation?
Referring to bad practices, a coup d'arc (or small weld deposit) to the body of a pipe A106 Gr B particularizing in new construction under the guidelines of ASME B31.3, Without having a material loss above 12.5% of nominal thickness according to the specification.
Heat input? Severely damages this steel?
Is it necessary to change the length of pipe?
rusbeli r
