Okay, I think we need to back up and explain ourselves a bit.
When you asked for a table, I ASSUMED (never do this at home without an expert assumer looking over your shoulder) you were referring to a table within the codes of D1.1 matched with D1.6 (carbon steel to stainless steel). To which my response was that there was not one and to accomplish the job you would need to do a PQR to qualify your materials and the filler which would be used to join them.
Now, you have changed the parameters of my 'assumption'. If 'any' table to match materials will do, I am sure there are several but I can't think of one off the top of my head. As Obewan said, Google it. It should be easy to find one.
Have a Great Day, Brent
Hi tofo
As stated by other forum members, there are many tables, but none will be complete. I will attach one which is typical of what you could get if you did a search. If you have a specific problem, please ask that directly and I am sure you will get more input.
Niekie
