Up Topic Welders and Inspectors / Welding Equipment Classifieds / Vantage 500 Cummins Diesel
- - By SRO1911 Date 08-05-2013 03:33
Changing careers and no longer need this much machine.  Its an 07 with 2713 hours, regularly serviced.
This is the full size vantage not the compact.
Looking for 9000 cash or will take a smaller machine in partial trade - 305g, 305d, vantage 300, chopped shorthood, ???  not a miller fan.
On a cash deal machine will winclude 200 foot of 2/0 leads, stinger, ground.
Machine is currently mounted on a 1996 GMC 1 ton crew cab drw, 454, auto, old tires, no A/C - will let the truck go with it for another 2500 (mostly just buying the CM company flat bed and boxes, little kicker for the stereo)  Truck does run and drive just fine, like most 1st gen vortec 454's it needs a fuel pressure regulator - a nice 10 dollar part buried under 5 hours of cussing.  Does not effect the way it runs, just means you have to crank it for 10-15 seconds to start it in the morning.  Tires on it are fair, but it has set a while - makes me leery, ymmv.
Welder fires on the first crank every time, runs like a cummins should, and welds like a Vantage...so nice.
Parent - By SRO1911 Date 08-05-2013 03:35
Forgot to add - - best way to reach me is to CALL 325 three three eight - 88three seven, between 8amCST and 11pm CST, calls at any other time will result in very unchristian responses. , im not around a computer too much lately
