Up Topic American Welding Society Services / Technical Standards & Publications / D1.2 WELDER QUALIFICATION RECORD
- - By KWoockman Date 08-07-2013 19:53
I am doing a fillet weld break test for a welder qualification per D1.2 and on the sample form it askes for "LENGTH AND PERCENT OF DEFECTS" and also "INCHES__________%". All the dimensions should come from the acceptance criteria found in Para, 3.10.3.1 but my question is what does the form want for information. Can someone send me a sample of what needs to go in these two spaces. Thank you in advance.
Parent - By 803056 (*****) Date 08-08-2013 16:05
Simply provide the sum of the lengths of all "defects" and then provide the percentage by dividing the sum of the "defects" by the total length of the weld minus the discarded ends of the weld.
