Up Topic American Welding Society Services / Certifications / ATF in Charlotte, N.C. ? Stainless cert?
- - By JPSweld (*) Date 08-09-2013 21:17
does any one know if there is an accredited testing facility in or near charlotte N.C.?  also, is there a pressure pipe certification for stainless steel pipe?
Parent - By 803056 (*****) Date 08-10-2013 17:21 Edited 08-11-2013 18:16
I don't know if there is an ATF in your area, but if you are interested in becoming certified to ASME Section IX, you must first qualify a WPS if you are a contractor. The act of qualifying a WPS will qualify the welder that welded the test coupon.
Parent - - By supermoto (***) Date 08-12-2013 17:16
CPCC at the Harper campus is AWS accredited and they can do any welder qualification you want.  Gonna cost you about $450 or more.
Contact a Steve Gore 704-330-4429 he will get you set up.
Parent - By 803056 (*****) Date 08-13-2013 20:38
One important consideration: Section IX generally does not allow third party certification. In other words, a certification issued by an ATF, AWS, or other third party to an individual (employee) carries little if any weight when working with ASME construction codes. Welders must be qualified/certified by the employer when ASME construction codes are invoked.
Now the issue is moot if the welder works for the ATF.
