Yeah, I can fully see the ramifications of such a decision.
I find it hard to believe it took so long to bite the bullet! Even so, they (AWS Committee) seem to have have left themselves open to further questions on this subject!
Are these queries/interpretations retrospective?
By 803056
Date 08-25-2013 14:56
Edited 08-25-2013 15:02
This particular inquiry was submitted several years ago (2008 if I remember correctly) and just now received an official response. Being a member of several AWS committees I know how long and winding the path is to get something through the subcommittee, the main committee, TAC, back to the subcommittee, back to the main committee, and back to TAC, until all parties can reach a consensus. One must consider the fact that these committees only meet a couple of times a year, so time is consumed very quickly when two or more cycles of approval are involved. Considering the repercussions this interpretation has, I can understand why it took a long time to get agreement.
This issue has come up on several of my projects over the years. I disagreed with the contractors' position that the welder could repair undercut using downhill vertical progression without further qualifications. This interpretation puts the matter to rest once and for all. It could also mean that there will be changes in the upcoming revision of D1.1. At least previous interpretations I’ve received have resulted in changes to the code and I see no reason why this will not be incorporated into the next edition of D1.1.
I agree with Brent’s observation that this interpretation does not represent a minor clarification. It has repercussions that also involve the qualification of a WPS using vertical downhill progression. My reasoning is as follows:
a) The welder must follow a WPS when taking the performance test.
b) The WPS has to be either prequalified or qualified by testing.
c) Since downhill vertical progression is not prequalified, the WPS must be qualified for downhill vertical progression.
d) Once the WPS is qualified for downhill vertical progression, the welder can use it to take the performance test.
Assuming my understanding of the code is correct; I have also suggested that the code be changed by moving clause 3.7.1(1), with an appropriate change to the provision numbers, to clause 5. Moving the provision to clause 5 should help clarify the requirements of the provision by removing it from the section addressing Prequalification.
When in doubt, ask the question and let the appropriate committees take the necessary action to provide an interpretation to clarify the intent of the provision. That is process by which our codes are improved and strengthened. The system may not respond as quickly as we would like, but it does work. Our standards have stood the test of time and they have industry backing because every sector of the industry has an opportunity to present their case. In the end, the best interests and safety of the general public are protected and strengthened.
