Hi Brent
Certainly some codes allow fabricators to use welder performance qualifications (WPQ) performed by other organisations, while some do not. I totally agree with your argument surrounding the liability issue when using WPQ's performed by other organisations, but this is a stance which is based on a number of assumptions which may not hold. The assumptions are:
1) You do not know the other organisation and therefore you have no basis for trusting their qualification process.
2) You do not have access to the welder's past performance history.
3) No independent third parties were involved in the qualification process.
If however you have WPQ's performed by organisations that you trust, with involvement of independent third parties and you have the welder's performance history available to you, then it becomes clear that "tried and tested" WPQ's (from other organisations, with a history of revalidation performance) should give you a much higher assurance of a welder's competency than a single test.
If there was a trusted system to register welders and their qualifications centrally, along with a mechanism to monitor and give feedback on their performance, then what need would there be to continually "re-test" welders when they move between employers? Keep in mind that even poor welders will pass coding tests, but not be able to perform consistently good welds, as well as good welders that occasionally fail coding tests. The only logical reason that the codes require re-qualification when a welder changes employment, is that the trusted system to communicate the necessary information between employers is not available.
For many years I had a consulting business that (amoung other things) helped fabricators to qualify their welders. (I know they are generally allowed to do this without third party involvement, but in many parts of the world this is a common practice.) In the case of "migrant welders" (agency welders that move from project to project) I often witnessed the same WPQ tests for the same welder a number of times a year. Even when the same welder returned to a fabricator that previously qualified him, but the 6 month "expiry period" had elapsed, he again went through the same coding tests. As an "outsider" in this process, it was clear to me that it was a waste of time, money and other resources. (I did however make money out of it, but clearly not adding much value in the process!) Because of this, I started to develop the idea of making an on-line system for administering WPQ's. While it is a simple concept, the actual market drivers are very complex, (Different parties want to protect their respective investments in different ways.) and therefore it took me almost a decade to come up with what I believe is a workable system. If you are interested, you can take a look at:
[url=]www.welderpassport.com[/url]
I have also made a "prezi" (Type of on-line presentation for those who have not come across this yet.) regarding this, which you can view here:
http://prezi.com/hpzr7jyu25ma/?utm_campaign=share&utm_medium=copyI believe that as long as all the necessary privacy and data integrity issues can be dealt with, we need to take WPQ's into a world of greater efficiency by using the power of the internet. We are doing it with everything else, so why not something like WPQ's that are crying out for efficiency and quality improvements?
Niekie
