I'm buying 250 feet of 2/0 welding lead. Have to go a bit of a distance, around 350 feet. This 250 will almost get me where I need to be at, probably have another 100 feet attached due to truck position and other variables. All they have is 250 right now and I'm headed out to the job before they can get in more. I have 400 feet of 1/0 lead so I can make up the difference.
My question is this. Which is the best location for the 2/0? Should I connect to my machine with the 2/0, then add my 100 feet of 1/0? I know ideally I should have the 2/0 all the way. If they can get me another 100 feet of it before Thursday I'll grab it up. Seems like I ran across this situation one time on extension cords but have not thought about it in 5-6 years and have slept a few times since then.
I will be running about 125-130 amps(maybe more depending on distance, how the arc reacts, etc.), 1/8" 7018 so amperage is not high but distance is. I believe my guy said 1/0 was rated at 300 amps at 200 feet. I did some rough calculations, divided 200 by 3 and added it to the 200. Figured I was running lower amperage so that, in theory should extend my reach. The length I have to be at was still further than my theoretical number of 332 feet(figured using 100 amps, 1/0 cable). Now, if I'm running 130-140 amps, turned up in order to push thru that much lead my 332 foot number decreases. All this is just me thinking out loud. On the 2/0 I believe he said 350 feet at 300 amps.
That's my situation. Right now I will be running 250 feet of 2/0 with 100 feet of 1/0. I think 2/0 connected to machine, then connect my 100 feet of 1/0 to get where I need to be. Am I correct in this thinking??
Thanks for any help!!
Shawn
