Was called to weld 3" threaded nipples into a couple of large tanks, about 10,000 gallons. One was stainless and not a problem, the other is aluminum. Not a tag or any type of identification anywhere on it. It was used to hold peroxide and is in place horizontal. The stab in will be on the bottom. Wondering if anyone has a suggestion as to the type of material. Wondering if there is a common alloy used to make tanks. The plan is to go with 4043 and my spool gun, oh and its out in the woods on the side of the road. Thanks Perley
