Up Topic American Welding Society Services / Technical Standards & Publications / My WPS has CC power supply. My welders are qualified with CV
- - By fit2inspect (**) Date 10-11-2013 17:58 Edited 10-11-2013 18:16
I have purchased several CC/CV welding machines, XMT350. I'm testing my welders using these machines.  When you’re welding with FCAW, CV mode is your power supply. My company has made a WPS with CC as its power supply at the request of our customer.
My super tells me I'm limiting my welders because I have been qualifying my welders with CV welding machines.  They can't weld on a job that has a WPS with CC as its power supply. I know what is in Table 4.5 line 15) a change from CV to CC. But I don't see anything in D1.1, about, what if you welding in CV when the WPS say’s CC. Would that constitute a essential Variable if my welders are welding with CV machines, or worse they qualified with CV machines. There is nothing in Table 4.12 as well.
Now on my Welder Qualification Test Record, I have typed for Actual Values on Current/Polarity, CV DCEP.  Across from it on Qualification Range it is blank. Can I type in CC/CV as there range?
If so where can I find this in D1.1.,that will allow my welders to weld either CC or CV if they qualified with a CV welding machine? Oh I forgot to mention. The WPS I have Qualified my welders from  has Constant Current for it's Electrical Characteristics.
Life is full of challenges, Thanks goodness for forum's
Parent - By jwright650 (*****) Date 10-11-2013 19:02
For pre-qualified status you have to consider AWS D1.1:2010 Clause 3.2.4.
I guess you could run a PQR and test the procedure if using CC for FCAW or GMAW...I just don't have any experience travelling down that road, never had a need to.
Don't forget that the welders will need to be qualified for SMAW, and FCAW or GMAW seperately according to D1.1 anyway...so I'm not sure why you would want to use CC for FCAW or GMAW just have the paper say that. Maybe I don't understand your situation fully....
Parent - By Duke (***) Date 10-21-2013 14:07
FCAW is a process, whether gas shielded or not, whether CC or CV. I don't see an essential variable dealing with variations within a process in T4.12 (other than GMAW-S).
- - By 803056 (*****) Date 10-12-2013 15:55
My first question is, "What welding code are you welding to?"
Next question is, "Why is the customer dictating the specifics of the power supply?" There may be a reason or someone may have got the wires crossed. The customer may have requested a particular electrode that requires DCEP rather than DCEN. It would not be the first time someone in the office did not understand the terminology.
If there is a concern on your part, ask for clarification.
Parent - - By fit2inspect (**) Date 10-21-2013 17:54
Your 1st question  answered D1.1 2010
Your 2nd question answered is they won't tell me. And they get very upset when I ask. I sent the NCR for an investigation no response. (possible wires crossed and they don't want to admit it)
The  WPS is written  Current/polarity across for it is. DCEP(CC Power supply)
My question: I have a super tells me that the welders I have qualify on, are with CV machines. I told him correct. He tell's me, therefore those welders will not be able to weld on the jobs that this WPS is assigned to, because the WPS is restricting the welders to use only CC machines. And my welders are not qualified to use CC machines because they tested on CV machines.
Better than that 80% of our welding machines are CV machines and we only use our old big blue CC machines to gouge with.
I told him Table 4.5 (15) it would be an essential variable if we changed from CV to CC output. Could you reword this so my super could understand this line better. I told him three different ways to Sunday and he told me it's what the customer wants.
Parent - - By 803056 (*****) Date 10-21-2013 18:46
It sounds like a total screwed up mess.
You stated the applicable welding standard is AWS D1.1. You didn't specify a year. Depending on the year, the prequalified WPS must use a CV power supply. If the edition imposed by the customer is prior to 2008 (or so) CV was not a prerequisite for prequalification.
Assuming your client has imposed an earlier edition, CV or CC is not a prerequisite for prequalification. The welder is qualified using a WPS that could be prequalified or one that has been qualified by testing, or possibly a SWPS purchased from AWS. Assuming the welder takes the performance test with a prequalified WPS, the welder is qualified for CV/CC and EP/EN because those variables are not essential variables for the purpose of the welder's qualification.
If the customer has impose a more recent edition of AWS D1.1, the issue of CV or CC only comes into play if the contractor is writing the WPS as prequalified. If that is the case, the WPS is not prequalified and it is in error and should be considered to be invalid by the Engineer or Owner.. The WPS for FCAW/GMAW must be qualified by testing per clause 4. If the WPS is qualified by testing, the PQR must indicate the type of power supply and the polarity used to weld the test assembly.
It could be  case where the person recording the test data on the PQR made a mistake. Just as plausible, the individual writing the prequalified WPS made a mistake and listed the power supply as constant current. It could be a case where no one wants to admit making the mistake and no one caught the problem during the review and approval process.
Keep in mind that AWS D1.1 allows the Engineer to circumvent, modify, add to, or delete the requirements of AWS D1.1. Such changes are to be addressed in the project specification. When there is a conflict or a question of the applicability of a clause, it is the Engineer's prerogative to issue a decision. The Engineer's decision stands unless a technical inquiry is made to the D1 committee and an interpretation is rendered.
If your customer, representing the Owner, is demanding that the welding be performed in a certain way, as long as the demand is in writing, that is the way the welding should be done. If there are problems down the way, whether it is nonconforming defects, failure to perform as expected, etc. your employer could face an uphill battle. If your employer tells you to do what the customer calls for, you do it and document every conversation and question asked about the customer's demands. It will come in very handy if there is a failure traced back to the welding, you can expect to be on the witness stand explaining why the welding was done a certain way. Trust me, at that point everyone from the Owner, contractors, mangers, supervisors, and the foreman will develop amnesia. The documentation you have to support your actions and activities will be your savior or the lack of documentation with be the rope around your neck.
Good luck my friend.
Parent - By fit2inspect (**) Date 10-23-2013 00:16
My pile of problems are deep. I'll ask him again how this all came about. I'm just taking it one shovel full at a time. See you on the next post. I'll let you know what happens. I haven't forgotten about the bender.
