Gents, I have inconveniences with a swing check valve, between the body and the hinger pin (plug bolt) we have a leakage (steam), to us is urgently avoid the leakage, for that reason I suggest perform a seal weld (fillet weld) between the body of te valve (SA 216 type WCB) and the plug bolt of the hinger pin (SA 470 type 410 - 13%Cr) using E7018 and PWHT 600°C.
perhaps I'm wrong with the filler metal?
I appreciate your comments
