Yes, the term "loss of head" in liquids means actually loss of pressure. This is because liquids are uncompressible. Loss of head is an academic expression that you can find in any mechanical or chemical engineering book written in English. I'm quite used to it, that's why I wrote it on my posting.
Gases, however, are compressible, so for gases loss of head means the increase of volume that the gas suffers for each psi of pressure drop in a piping. Mathematically, loss of head = V dP.
I thank you very much for your kindness in searching the article and deliver it to me. I took a quick look to it and will read it carefully during the next days.
Again, thank you very much.
