Up Topic Welding Industry / General Welding Discussion / valve repair
- - By jwmacawful Date 11-18-2013 10:27
in the mechanical equipment room there is a leaking steam elbow. upon removing it to replace the gasket i noticed a groove in the flange face. the pressure is around 150 lbs. the elbow appears to be cast iron. can i fill this with a nickel rod? how about pre or post heat?
Parent - - By G.S.Crisi (****) Date 11-18-2013 18:55
"The elbow appears to be cast iron."
You must be sure, not only believe that it's cast iron. With a file, file a few decigrams of material from a place that won't cause any harm and take it to a chemical lab to run a chemical analysis.
I personally would say that it's not cast iron. It's a long time that cast iron fittings aren't use for steam any more.
Parent - - By jwmacawful Date 11-19-2013 02:10
i also wasn't convinced it was cast iron even though the fitting must be 50 years old and any markings are long gone. i cleaned it and heated it then tried 7018 with bad results. i reground it and used a nickel rod and now i believe it is a cast iron fitting because i had very good results. after welding i wrapped it with insulation and fire proof drop cloths. on most jobs asking to have a sample taken to a lab would be a reasonable request. i regret to say my place of employment is not one of them. thank you for your reply.
Parent - - By Superflux (****) Date 11-19-2013 08:08
http://www.scrapmetaljunkie.com/241/the-spark-test-and-spark-testing-metals-2
http://en.wikipedia.org/wiki/Spark_testing
http://everythingscrapmetal.blogspot.com/p/metal-test-identification.html (this has some good low tech mechanical tests! See chipping test chart)
For starters, I always recommend a simple spark test for non code/ non critical repairs.
Parent - By jwmacawful Date 11-19-2013 10:10
as a longtime welder i am aware of the spark test but didn't think of it at the time. should have listened to my father when he said "kid, don't get old it stinks".
Parent - By Cumminsguy71 (*****) Date 11-22-2013 22:30
"i regret to say my place of employment is not one of them"
Haha, sounds like you and I have worked at the same place!!
