A633
is a normalized HSLA plate steel for applications where improved notch toughness is
desired.
Available in four grades with different chemical compositions, the minimum yield point
ranges from 42 to 60 ksi depending on grade and thickness.fschweighardt does make an important point about the A633 possibly being a ferritic steel but, the real question here is which specific grade are we talking about here Jordan???
Is it the grade with small amounts of Cr, NI, and Cu with a very slight higher amount of Mn (D), or the grade with less C(A), or is it the grade a tiny amount of Vanadium, or the grade with a tiny amount of Moly (C), or the grade that has no niobium but has a very small amount of N (E)? There are some variations in the composition with respect to the exact % amounts of the micro-alloying elements depending on thickness and mill form for one grade, and one grade has the option of including some of the elements or not that distinguishes that grade from the other ones... So, which grade is it? A,C,D or E???
Here's a .pdf from ASM that covers A633 as well as the other four out of six grades of HSLA Steels, including: Weathering Steels, MicroAlloyed Ferrite - Pearlite Steels, As Rolled Pearlitic Steels, Acicular Ferrite (Low Carbon Bainite) Steels, Dual Phase Steels and Inclusion - Shape Controlled Steels...
http://www.asminternational.org/content/ASM/StoreFiles/06117_Chapter%203B.pdf#page=3&zoom=110.00000000000001,26,536So this may or may not be important enough but then again, it just may be.
